runs natively on Macs with new Apple Silicon chips
text snippet macros are now supported in the ‘condition description’ field
Bulk Search & Replace panel: added an ‘Exact search’ option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
icons for listings in the Main window outline view should reflect listing state changes more quickly
Shipping options panel: package weight can always be edited when ‘calculated shipping’ is used for either domestic or international shipping
category popover shows category tree version in sprocket menu when option key is held down
fixed a crash when updating incomplete local listings with data from eBay
However, the Search field in the toolbar is 1px wide…
(I can work with it only because I know what I’m expected to do once it’s selected )
Update: also, it looks like the Update Listing button in the toolbar isn’t working? It remains a little circular arrow when clicked, and also when I manually select the menu item.
Thanks for reporting. We’ll release a version as is for everyone first, so build have at least something that doesn’t crash, and will try to come up with fixes for the toolbar problems shortly afterwards.
The disappeared smart groups is NOT a new thing. It happened a few months back to me on an earlier version. And yes, the restart made them reappear so I didn’t report it.
It fixes a timing issues while setting up the outline view during application startup, which might lead to the missing smart group issue. Not 100% sure though, since we could never reproduce the problem so far.
