GarageSale 8.4 Alpha 8 Released
an new alpha release (a very early development release for preview) of the the upcoming GarageSale 8.4 is available for you from this address:
https://downloads.iwascoding.com/downloads/GarageSale_8.4a8.dmg
What’s new in this pre-release
  • added new Preferences settings (under eBay > Advanced) that prevents automatic switching to ‘Live’ view when listings are started
  • macro language placeholders in mobile summary are resolved when posting to eBay
What’s new in GarageSale 8.4
  • GarageSale no longer prompts for choosing a payment method if “Managed Payments” is activated for your eBay account (requires OAuth token, see above)
  • If you are using profiles for shipping or returns, GarageSale will no longer prompt you to select a Payment profile (requires OAuth token, see above)
  • Order section: New context menu entries in the order outline view to change order state (e.g. “shipped”) for selected orders
  • GarageSale will prevent you from starting auction-style listings, when the auto-cancel feature is enabled
  • Attributes window: enabled ‘autocompletes’ option for certain attributes (e.g. ‘Artist’ attribute in LP/Records section)
  • Synching: re-worked conflict algorithm to reduce the number of times the Conflict window appears
  • added AppleScript command to manipulate shipping weights
  • various crash fixes
  • text entered in the “user properties” area of the inspector is now searchable
  • new smart group rule for searching “user properties” content
  • GarageSale generates a ‘mobile summary’ from the first 800 characters of your listing description when uploading listings, which does not include GarageSale’s version identifier string
  • the ‘Reveal Original’ command is available from the overview context menu (middle area) in the listing section
  • the number of images used in a listing is shown in Editor mode
The GarageSale team
Works Great!! Thanx!
This is Fixed.
But… My description is still “duplicated”. Happens on desktop/macOS and also in the eBay mobile app, “See full description” link. See photo below.
https://www.ebay.com/itm/353663264524
The ballon Help (popup help text) is not correct for this preference (it is the same as the preference above it), and the “Select new listings after Relist” preference help text seems to have odd wording.
Also, the “Prevent system sleep …” preference help text is the same as the “Remove categories” help text above it.
Glitch in token. I refreshed the token two times. Neither time worked. Quit GS 8.4 alpha 8 and restarted. No go. get this prompt screen.
Yes I do have payment profile selected. Turned profile off, back on, removed PayPal email address, nothing helped. Went back to 8.3.6 and refreshed token and started listing right away
Thanks for giving it a try. Will go to through our code another time to figure out what the error could be.
see alpha 9 comment for my update
