GarageSale 8 Beta 46 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b46.dmg
- Users can reset their data on the synching server by disabling synching from the GarageSale Pro preferences, and clicking “Reset Data on Server” after enabling synching again
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
