GarageSale 9.0.3 Released
GarageSale 9.0.3 is available for you from this link:
https://downloads.iwascoding.com/downloads/GarageSale_9.0.3.dmg
What’s new in GarageSale 9.0.3
  • fixed an issue where leaving feedback marks the order as not shipped
  • the part fitments panel should no longer report an error 400 in some rare cases
  • amount fields again accept values with German localization (comma separator)
What’s new in GarageSale 9.0.2
  • fixed an issue with the availability of the ‘Best offer’ options panel
  • fixed issues with tab view in the inspector only having a single entry
  • tweaked order table to improve width of title field
What’s new in GarageSale 9.0.1
  • the prospective end time for auctions is shown below the duration popup in the listing inspector
  • added horizontal split view to ‘Send Offer to Watchers’ panel
  • fixed issues with “Move Selected Items To” command
  • images for orders whose listings are not GarageSale’s database are also shown in overview mode
  • added support for eBay’s new API to download attribute and category data, as some of the attribute APIs will be shutdown by eBay
  • users can attach videos to eBay listings
  • support for eBay’s “Send Offer to Watches” feature lets you send offers to watchers in bulk
  • [users can manipulate their eBay listings using custom JavaScript scripts] (Running Scripts)
  • [users can hook their own JavaScript rules into GarageSale’s Launch Control window to have their listings validated before uploading them to eBay] (Validating scripts when launching listings)
  • downloads and displays fee for usage of eBay’s payment service
  • you can now import items from GarageSale Scout, GarageSale’s iOS companion app, as inventory items
  • messages received eBay’s messages system can be flagged
  • part fitment information for vehicles is imported when the “Import from My eBay” command is used to import listings
  • added an SKU generator function for listings and inventory objects
  • the font size of used in the right-hand outline view can be adjusted through the “Side icon size” setting" in the macOS General System Preferences
  • right-hand inspector’s width can be changed
  • you can assign colored tags to your listings and orders, and filter for these tags using smart groups
  • the main window toolbar is now customizable
  • XML import works for design properties representing colors
  • Orders section: the listing table row height now depends on the setting of the ‘Sidebar icon size’ settings in the macOS General preferences
  • the ‘Move Selection To’ command now moves groups selected in the outline view, instead of the group’s content
  • GarageSale downloads images for orders if the listing for the order, and thus an image for the order, is not in GarageSale’s library
  • Orders section: added context menu item to change sort order for subsequent sort commands
  • added a new Preference settings that optionally brings up panel for inserting specific attributes into new listings
  • a listing’s variations can be manipulated via AppleScript
  • the ‘read’ state of eBay messages is now transmitted to eBay
  • reports: added ‘Total fee’
  • reports: shipping costs are no longer added to profits if you didn’t fill in ‘actual shipping costs’
  • added count badge when dragging items in outline view
  • image upload operations show the name of associated listing in the ‘Activity’ window
  • Listing section: shipping options strings shows dimensions and weight when calculated shipping is used
  • GarageSale will show a warning when you are trying to open 10 or more listing links in your browser
  • Orders section: replaced “Feedback Left” checkbox with “Leave Feedback” button, when no feedback was left yet
  • Listing preview: return policy label updates correctly when return policy changed
  • ‘SKU’ field can be selected as separate option in the “Revise Listing” panel
Synching
Cost
  • macOS 10.12 or later
