GarageSale 9.0.5 is available for you from this link:
https://downloads.iwascoding.com/downloads/GarageSale_9.0.5.dmg
What’s new in GarageSale 9.0.5
- fixed issues listing on eBay Belgium
- the “Move originals to Trash after duplication” checkbox works when selected items are part of a smart group
- added a simplified ‘Start Listings’ toolbar item for older macOS versions, which had problems displaying the standard “Start Listings” toolbar button
- the remaining listing count in GarageSale’s Pro preferences updates more quickly
- GarageSale will show an alert when token errors prevent the Preview from loading
- inspector immediately updates when pasting ‘Store settings’ component from other listing
- inspector immediately updates when pasting ‘Barcode’ component from other listing
What’s new in GarageSale 9.0.4
- fixed a crash after receiving an empty response when asking eBay for category metadata
- fixed several quirks with the parts fitment features
What’s new in GarageSale 9.0.3
- fixed an issue where leaving feedback marks the order as not shipped
- the part fitments panel should no longer report an error 400 in some rare cases
- amount fields again accept values with German localization (comma separator)
What’s new in GarageSale 9.0.2
- fixed an issue with the availability of the ‘Best offer’ options panel
- fixed issues with tab view in the inspector only having a single entry
- tweaked order table to improve width of title field
What’s new in GarageSale 9.0.1
- the prospective end time for auctions is shown below the duration popup in the listing inspector
- added horizontal split view to ‘Send Offer to Watchers’ panel
- fixed issues with “Move Selected Items To” command
- images for orders whose listings are not GarageSale’s database are also shown in overview mode
- added support for eBay’s new API to download attribute and category data, as some of the attribute APIs will be shutdown by eBay
- reports: added ‘Total fee’
- ‘SKU’ field can be selected as separate option in the “Revise Listing” panel
Synching
Cost
- macOS 10.12 or later
