Beta 17 of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b17.dmg
What’s new in Beta 17
- fixed manual account update functionality broken in Beta 16
What’s new in Beta 16
- a listing’s attributes/item specifics are accessible from JavaScript via ‘attributes’ property
- improved eBay token handling
What’s new in GarageSale 9
- added support for eBay’s new API to download attribute and category data, as some of the attribute APIs will be shutdown by eBay on April, 20th
- reports: added ‘Total fee’
Synching
Cost
- macOS 10.12 or later
