GarageSale 9.0 Beta 2 Released
The second beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b2.dmg
What’s new in Beta 2
  • Listing preview: return policy label updates correctly when return policy changed
  • Listing section: shipping options strings shows dimensions and weight when calculated shipping is used
  • Orders section: added context menu item to change sort order for subsequent sort commands
  • Orders section: replaced “Feedback Left” checkbox with “Leave Feedback” button, when no feedback was left yet
  • GarageSale will show a warning when you are trying to open 10 or more listing links in your browser
  • fixed some minor interface glitches
What’s new in GarageSale 9
  • supports eBay’s new API to download attribute and category data, as some of the attribute APIs currently used by GarageSale will be shutdown by eBay
  • you can attach videos to your listings
  • you can send discount offers to watchers of your listings in bulk
  • you can assign colored tags to your listings and orders and filter for tags using smart groups
  • added an SKU generator function for listings and inventory objects
  • right-hand inspector’s width can be changed
  • reports: shipping costs are no longer added to profits if you didn’t fill in ‘actual shipping costs’
  • reports: added ‘Total fee’
  • part fitment information is imported from eBay via the “Import from My eBay” command
  • messages received eBay’s messages system can be flagged
  • the ‘read’ state of eBay messages is now transmitted to eBay
  • you can now import items from GarageSale Scout, GarageSale’s iOS companion app, as inventory items
  • a listing’s variations can be manipulated via AppleScript
  • downloads and displays fee for usage of eBay’s payment service
  • the Font size of Outline View can be adjusted (through System Preferences)
  • new preference settings brings up panel for inserting specific attributes into new listings
Synching
Licensing during Beta phase
Cost
  • macOS 10.12 or later
You have a glitch somewhere. The preview mode is completely blank. Editor and live ok
is the preview blank when any listing is selected? Or just some of them? Can you export the template and send it to me?
It is when the listing is selected. ALL of them. I exported to my desk top but it won’t paste to this screen
I went back to 9.0b1 and it is fine
I downloaded a fresh copy of 9.0b2 but still the problem persists. I looked through all the settings and don’t see a problem. 9.0b1 is fine
Can you export one of your listing and send it to GarageSale support?
In your listing do you use any custom code, text snippets, or your own listing design?
No custom code, text snippets or my own listing design. Just GS PRO listings from the list.
I sent an export to the GS support
I tried other designs from the list and still blank. Went back to 9.0b1 and the new listing shows fine
Thank you. Maybe it has to do with the new string for shipping, we’ll see.
Just a short “Thank you” for going on with the development of GS!!!
Maybe that’s a bug specific to a certain version of macOS. What version of macOS are you running?
The Mac version 10.15.7. You cant reproduce it?
Not yet, but I don’t think we have test the last beta on 10.15, because it only contained minor changes. Seems one of those changes cause GarageSale to trip on that version of macOS.
Is mac 12 stable on your machines? I hate to update when everything is working smooth
We could reproduce the issue thanks to the listing you sent in. It has nothing to do with the macOS version.
Turned out, the specific shipping setup in your listing run into a newly introduced bug when rendering the preview we didn’t catch, because we were using different a shipping setup during testing.
It’s now fixed in beta 3.
