The sixth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b6.dmg
What’s new in Beta 6
- some work on fixing scrolling when duplicating or dragging & droppings items in outline view
- fixed truncated labels in accounts table view in preferences
- when GarageSale starts, the last selected item(s) should be correctly restored
What’s new in GarageSale 9
- reports: added ‘Total fee’
- the new ‘tag’ property on listings is are now accessible via AppleScript
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
