the final version of GarageSale 9 is available for you from this link:
https://downloads.iwascoding.com/downloads/GarageSale_9.0.dmg
What’s since the last Beta version
- ‘SKU’ field can be selected as separate option in the “Revise Listing” panel
What’s new in GarageSale 9
- added support for eBay’s new API to download attribute and category data, as some of the attribute APIs will be shutdown by eBay on April, 20th
- reports: added ‘Total fee’
Synching
GarageSale 9 uses a different data scheme compared to previous versions. When GarageSale 9 connects to the sync server for the first time, your account is upgraded to this new scheme version.
Afterwards, earlier version of GarageSale can no longer connect to the sync server.
Cost
- macOS 10.12 or later
