Tonight as I was watching to see that my auctions became active, three times GarageSale closed unexpectedly. This happened several times before. If I’m not at home when the auctions are scheduled, I loose my sales for the week when this happens.
Do you know at what step GarageSale closed unexpectedly?
I am using GarageSale 6.9.8, I believe it is the latest update from the App Store. I’m also running the latest OS Sierra 10.12.5. Thank you for your reply.
Cathy
I actually don’t know at what step is crashes, I just check when I don’t see the auctions coming up on my iPad then go to check my MAC and find that it has closed. It also closes sometimes when I add additional photos while preparing auctions.
You then should consider to upgrade to GarageSale 7. You can download and test it for free:
http://www.iwascoding.com/GarageSale/
Also, GarageSale 7 can import your GS 6 library and your accounts upon first launch (this process may take a while) so you won’t lose any work. It uses its own database, so you can run it along side GS 6 without side-effects.
I purchased the update to GarageSale 7. In version 6, I routinely duplicate an auction template then “delete all images” and add new photos and do appropriate changes to the listing. I can’t find anywhere in 7 that lets me delete alll the images at once. It must be there somewhere! Help!!
I found the “delete all images” under listings. The old version with it under images makes more sense, but at least I finally found it.
