I’m using GS 7 Beta 19 but copy and paste listing components doesn’t work anymore. Until beta 18 it worked great, now when I try to paste one or more components it reset all.
Thanks, we’ll look into this.
Copying and pasting listing components should work again in this build:
http://downloads.iwascoding.com/downloads/GarageSale_7_2016-03-30_1.zip
Can you please verify and let me know if it works for you?
Yes, it works. Thank you.
Can I erase the old version from my applications and replace with this? Nothing will change?
Yes, please use this version until a the new beta version is released, which will include the fix and possibly others.
