Example 1:
eBay says 10 available. Once I import the listing into Garage Sale it says 14 available.
I update the listing from Garage Sale, eBay changes to 14 available.
Example 2:
eBay says 4 available. Once I import the listing into Garage Sale it says 3 available. I uncheck the “quantity” box. Revise listing, eBay now says 1 available.
How can I get Garage Sale to stop changing the quantity available when I import or upload my listings? Please help ASAP!
The “Import from My eBay” command imports the original quantity of the listing into GarageSale.
So, if you don’t manually reset the quantity after importing, or make sure the “quantity” field is not selected in the Revise panel, your listing will get reverted to its original quantity after a revise.
