Hi guys
I have forgotten where the GS9 database lives? Used to be in containers but not now.
Hi guys
GarageSale keeps your database in your User Library* under
Macintosh HD/Users/yourUserName/Library/Containers
Under macOS Bis Sur or Monterey that database folder is probably just called “GarageSale”.
*Please note: The User Library is hidden by default. To access it click the Finder’s “Go” menu and press the option (alt) and shift key to make the User Library show up in the menu. Selecting it will open it in the Finder.
Cheers, Kristian.
I know it had changed and your message helped me find it.
/Users/davide/Library/Containers/com.iwascoding.garagesale9/Data/Library/Application Support/GarageSale
