Garage Sale v.6.6.6
Mac OSX 10.6.8
Select “Design Store” and GarageSale spins-its-wheels in preview window…help?
When you select the “Design Store”, does there any output appear in the Console utility (you can open it from /Applications/Utilities/).
Hello:
Thanks for responding and Yes:
15-01-10 4:48:22 PMcom.apple.launchd1 The following job tried to hijack the service “32C7DB2D-5274-4664-806A-FE130293A87D” from this job: com.zeobit.MacKeeper.AntiVirus
I would assume that this can be interpreted as a conflict with MacKeeper? If so, any suggestions?
Henry
Hi hydunsmore,
my suggestion is to uninstall MacKeeper. If you don’t want to do this try to disable MacKeeper’s “Real Time Protection” feature. Uncheck that feature and the “Safe Browsing” feature and restart your Mac.
Maybe it already helps.
I found macKeeper a real pain and installed it.
