I was trying to delete a single listing and deleted an entire group of about 50 items.
I can’t find the group in my list of deleted items (which is about 11,000 items) and can’t seem to recover the group. I can’t recall what I called the group.
How can I recover those listings on GS?
Your deleted listings (and group) should appear in the trash bin so it’s worth a try to have another look!
Do you have a system backup, e.g. Time Machine?
The version of GS that I’m using is 7.0.9
My Time Machine is not working. I’ve gone through the trans over and over and there is no system to it and there are over 11,000 items.
I’ve been going through deleted listings is that the same as trash?
Yes, that “Deleted Listings” item with the trash bin icon.
I “might” have located them but I’m still nervous. I was able to order those items to find the most recent deletes and they should be the only items still running.
I guess I have to remember to empty the trash now and then.
I can’t empty the trash. Can you tell me how to empty the trash?
Sure, simply right-click on the trash bin icon and select “Erase Deleted Listings”.
Did you find your lost listings?
