I need a smart listing group that will show all ACTIVE listings for one of my accounts.
I can select the seller account but the only options under status are ‘show items with bids’, or ‘items without bids’. How about both ? Is there no way to create a smart group just showing all my active listings whether they have bids or not ?
Also, is there not a way to search these forums ? It would definitely help viewing other people’s questions on the same topics.
When setting up a smart group you can add multiple rules. You can select “active item with bids” and “active item without bids” in addition.
However, there might come simplified “global listing state” rules for smart groups in on of the next versions of GarageSale. (prepared, active, ended)
