I had a couple questions. Fairly new to the new Garage Sale layout. When I starting typing a description, sometimes some words will start to be auto detected and fill out automatically which is really annoying because the word might be the title of a movie I’m listing and needs to be capitalized and the auto detect is lower case, so I have to go back and edit it. Looking to turn this feature off. Second is how do I format paragraphs in my listing. I will hit return twice in the field where I’m typing the listing but when it’s done and uploaded, the listing is all one big paragraph with no line breaks. Thanks!
If you’re in Editor mode select “Convert styles test to HTML” from the “Description Conversion” menu at the bottom. Line breaks will be converted to HTML and visible in your live listing.
