Hello, I’ve searched but have been unable to locate controls for these desktop notices.
I could like to turn them off.
Does anyone know how to do so?
thank you.
thank you.
Hi Robin,
you can adjust/disable notifications in the System Preferences>Notifications.
Yes, but where is ‘Notifications’???
I’m using GS Version 6.9.6b4 (616).
OK, I found it.
You meant the APPLE system preferences.
I was hoping to adjust it so only Sold items created a notification. Apparently the only choice is OFF/ON. Too many unsold notices, and it takes too much time to delete them.
