Hello, I am new to Garagesale and I want to import the data I currently have on Etsy to my eBay store using Garagesale.
- What format do I import my data
- Where can I find the fields needed
Any help will be greatly appreciated
Hi ariehb,
if you could export or convert your etsy data to XML you could use GarageSale’s XML import format:
http://wiki.iwascoding.com/mediawiki/index.php?title=XML_Import_Format
