I’m having a very rough week. My hard drive failed, and my backup company is apparently not the good service I thought it was.
So, I’m manually restoring stuff.
Here’s my GarageSale problem:
I used the “Import from My eBay” feature to retrieve my templates, and that worked almost okay. I can see them, but it appears I cannot switch or add photographs, nor can change such things as the positions of the photos on a template.
Looking at Templates -> Listing Design, i see no design is chosen, and when I add that to the existing template which has been imported, it bumps what I have to the bottom and is, essentially, a blank template on top, and the imported section at the bottom.
I’m sure that there is something I’m doing wrong, but I can’t figure out what it is. I have about 200 templates to put back together and my frustration level is through the roof.
Help!
