Is there any way of writing the following in preview mode?
You are bidding on [[itemTitle]]
The condition of the item is {{ItemconditionDescription}} ??
SKU:{{ItemSKU}} ??
I tried using [[itemTitle]] I found in the message template selection and it does not reveal when I hold down control option like message snippets do. So no copying in from the title in the description?
Whats the correct format of the inserts so I can copy some of the variables to the item description?
If you are only using Editor mode for editing your description, you can use [[ and ]] as enclosing characters for placeholders. In Preview mode you need to use {{ and }}. Hold down the control and option key in Preview mode to see how your placeholders are resolved.
