Is it possible to list an item with Garage Sale and use no background?
yes, sure, you don’t have to use a listing design! Simply select “Don’t use a design” in the design browser:
https://manual.iwascoding.com/gs7/en/Listings_Section-Designing_Listings.html
Hint: If you still want to be able to use one of the layout options and also ensure that your listing is optimized for smartphones, select the “No Design” design!
