I am trying to list a DVD box set and the following error is being returned each time I try to upload a BIN listing
Any ideas what this is? and how to remove the problem?
XML Error Text: “; nested exception is:
org.xml.sax.SAXParseException: The entity name must immediately follow the ‘&’ in the entity reference.”.
I fixed my own issue. This happens because I used an Ambersand & in the SKU field. Every day is a school day
I googled it and found this comment
I have experienced this error message too and it was caused by having ‘&’ in the attribute value. Eg Colour: Red & White. I replaced the ‘&’ with ‘/’ - Colour: Red/White and it worked fine.
worth a try?
I only just figured it out myself just now and you had the write answer. many thanks
system
Closed
January 27, 2017, 5:55pm
5
