Howdy,
I accidentally deleted some of the default Item Attributes.
How can I restore missing attributes?
Thanks!
Howdy,
Thanks!
Hi Craig,
the easiest way is to delete the item specifics at all and then re-open the item attributes popover. The default attributes should be added then automatically.
Kristian,
I’m having a dumb as rock moment here
I reinstalled Garage Sale over the existing installation (f I deleted the entire application would my existing listings get lost? I’m scared to find out.
Here is a brand new listing after quitting and re-starting GarageSale. You see the add detail box is open. Where are all the other attributes?
Help me, Obi-Wan Kenobi – you’re my only hope
C
Craig Parks
craigparks@me.com
Kristin,
Dumb as rocks. I just noticed that these attributes are dynamic depending on the category of the item.
Oy, I feel soooooooo stupid.
Can you ever love me again?
C
Craig Parks
craigparks@me.com
Don’t worry, no problem.
That’s true.
Just deleting the application won’t touch your existing GarageSale database.
