JavaScript listing property for Item ID
Is there a javascript listing property for item id? Only saw it in the applescript dictionary.
Did not see one in the manual.
The eBay itemID will be available as a JavaScript property with GarageSale 9.1. Let me know if you are brave enough, and I’ll send you a pre-release version.
I need to figure out the image URL issue from my other post before I can make much more progress using javascript. thank you
