Sorry, I cannot give you a general answer. Proxy settings are complicated and GarageSale 7 uses only Apple’s network code, which in theory should honor your proxy settings. The best way to find out is give it a try.
I would be very interested in testing version 7, especially since 6.9.7 won’t run on my system since I upgraded to El Captian 10.11.1. Is the offer still open?
I get no further than the icon bouncing in the dock for what seems like longer than usual, then the icon simple disappears and there is nothing. No error message, just back to a normal screen like nothing happened. It was working just fine until the last el capitan upgrade.
I got the invite for version 7, downloaded it and it started up fine. Wow does it look different! While it seems to have imported my data all right it seems to have changed many of my folders around and I am going to have to sort that out.
I deleted the MAS receipt in the library folder and 6.9.7 has started up finally but now says it is a "demo version”. sigh. I was not asked to enter a license number and even if I was I don’t have one to enter. I went thru some challenges with the program last November with the upgrade to 6.9 and who had my license number - your the apple store - did get the software running but never did end up with a license number. I have bought the software twice now, originally from the apple store and then again from you and it looks like I will be doing so again for version 7. sigh. I am guessing the smart play is to buy from you direct and not the app store correct?
GarageSale 7 won’t be available from the Mac App Store anymore. Long update time, unreasonable demands by Apple’s reviewers, no way to contact customers after reviews - the Mac App Store is just a nightmare for developers like us who have to adapt quickly the eBay changes.
Love GS6. I have the MAS version but have no issue with apps being non-MAS. I run El Cap on a MBP 13. If there are spaces, I would love to try a beta of GS7. I have used GS6 such a lot I am definitely in line for buying an upgrade. On the final release, will it be possible to upgrade from a MAS GS6 to a non-MAS GS7 and be able to delete the older version (I hate having older versions lying around, but won’t delete until the final release.
