But do you mean you have all your listings divided in folders? Each folder for a category? Did you set the output folder for that listing in a specific folder? Mhm I did not have this problem, I have just one output folder where all listings go after activation, besides it crashes only when it freezes and I don’t have to restart…
Yes, my listings are divided into folders. The output folder is supposed to be Deleted Items but both the duplicates and the newly listed are both just being piled on top of the deleted items folder.
Here is a screen shot. You can see that it is moving both active and duplicates to the same place but not into the Deleted Items. The active items should have stayed where they were.
I have a similar problem. When relisting items and clicking on the folder icon at the bottom of the launch control window to send the original to the deleted listing folder, they end up just above, not IN the deleted listings folder.
I’m still unable to reproduce this behavior. I recorded a short animation, maybe this way we can figure out what’s going on.
I have listing called “Testing”. Its icon initially shows a dotted border because it’s not started yet. I set the “Launch Control” options to move the listing to the folder “Destination” after launching and to create a duplicate in the original location.
After the start, “Testing” turns light blue and is moved to the new “Destination” folder. An new duplicate listing (dotted border) appears at the listing’s original location.
If I got you correctly, the original listing (light blue after start) stays at the original location and the duplicate (doted border) gets moved the new destination. Correct?
YES! That did solve it. Thank you. I needed to have nothing checked.
However, why is there not the same “move originals to trash” option for re-listing as for starting auctions? Having to go through and manually delete them means a lot more work with thousands of items.
