One more question… how to I set UK visibility to my options on my listings? It doesn’t seem to add when I try to list it. I checked international visibility.
Ian
Hi Ian,
you can enable it in the “Enhancements” options in the “Advanced” Inspector.
Can you post a link to that listing so we can check it? Also, did you enable internationl shipping options? Did you exclude countries?
