the new feature works great, GS downloads images from eBay if the listing is not in the database, but if you select a group of listings, or if you click on a smart folder and switch the display to show listings as “square with images”, those listings does not show the image:
Other listings in the database shows images correctly. Hope this could be fixed.
Thank you
Federico
