Pre and Post OSX Capitan Garage Sale update, using Photo Drop Zone: when I rotate a picture (clock wise or anti clockwise, by Cntrl & Mouse Click menu selection) an ‘Image Error An error occured while trying to generate an image for the listing preview.’ message appears. Image appears lost but shut down reopening of programme then makes rotated photo available.
this might be an issue with your image or auction template.
Does it happen with a newly created auction template and another image, too?
You’re using GarageSale 6.9.7?
Using 6.9.7, happens on all images Replacing deleted imported from eBay images, on imported templates. Happens to all images.
did you only test it with listings imported from eBay (using the “import from eBay” command form the FILE menu)?
I have tested on a new template, the problem does not present in this case. So the issue seems to be only with eBay import templates.
