Normally before the last two updates, when I put pictures into a folder
They normally appear here in the new stock, however, this is not happening and its a lot of effort to get them to appear, normally I reset my machine.
Ive tried the right click and reload both on the folder and on the photo’s app and this is doing nothing.
Can anyone tell me if this a bug of the software or is it something?
I am not sure if there’s a way to prevent it from happening. Did you make any changes to the settings of the Photos application recently?
Hi No changes, it started after the last two updates from you guys
ilja
#4
Sometimes you need to quit and restart both the Photos.app and GarageSale to make new images appear. Maybe this helps.
system
Closed
#5
