I am new to GarageSale, and cannot work out if I can re-list an eBay auction after 90 days has expired? I typically have about 100 Listings, but leave the country every year for 4 months, and would like to be able to delete all listings before I leave, and conveniently relist them after I return.
I see under Preferences that I can set “Delete finished auctions” to “Never”. I also see GarageSale saves “Deleted Auctions”. How do I use one of these options to then select and re-list as before, with full pictures etc?
GarageSale will let you re-list an auction, even if it has been ended 90 days ago. I’m not 100% percent sure if eBay will let your re-list go through after three months, but if re-listing fails you can always start an identical listing from the old one.
Here is what I would do:
Once you are about to leave the country, shift-select all the listings you want to end in GarageSale in the left-hand outline view (hold down the shift key to select multiple items)
Choose “Stop Listings” from the “Listings menu” to stop them all
Once you are back, select all the listings and choose “Re-list listings” from the Listings menu. This will also upload your images again if needed.
Thank you IIja, I appreciate your help. But I do not see a “Listings” Menu
_ I am using v.6.9.7 on a Mac (Safari 10.0). I will attach a screen shot
of the menu that comes up.
I see. Generally the strategy would be the same for GS 6. However, the terminology used in this version is a little different. Some of the menu commands I mentioned are in the “Template” menu, while others are in the “Auctions” menu.
If you just got started with GarageSale, it’s better to switch to version 7 right away. Some stuff has changed, and it’s most likely pointless to learn how to use the GS 6 at this point.
