Hi. I have had to refund a buyer for items that were no longer available. However, under “Orders - Smart Groups”, the item is still showing as Waiting for Payment and won’t disappear. How do I update this and delete?
in the Order section did you already select the “Money refunded” checkbox?
Yes, that’s correct. There were three orders that were part of the same transaction - two were refunded, one was paid for.
Rgds
Nick
Could you send me a screenshot of your “Waiting for Payment” smart group settings? (double-click on it to open the settings)
Hi Kristian
Attached. The problem transaction is ‘Dr D G Harries’. The paid part is showing under the Orders header.
Rgds
Nick
Thank you for the screenshot.
These are not the default settings as far a I can tell. Please give these settings another try:
Thank you Kristian - this is now resolved.
One small question: what is the difference between the greyed out shopping cart icon and the cart that is clear? I cannot find out!
Thanks
Nick
Read/Unread
See: “Icon Legend” from the Help menu
