when i try to relist a single item from my Vorlagen list GS tells me in the control center sometimes that I am not the original owner or it can not find the article.
I using more then one ebay account, do I have to specify which one to use?
you can only relist a listing using the same eBay account that you used to start the listing initially.
In that listing you maybe selected a store category that belongs to a different shop/account and that’s why you get this error when trying to relist the listing? That’s just a guess though.
How can I switch between accounts then? If I use the drop down menu to list it again instead of relisting it will always delete the category. Is that intended?
