Hello everyone. any ideas on this… ive treid everything… deleting polcies etc…
still showing.
al the best
still showing.
al the best
i have read on here you offer international returns it solves it… but i dont offer that… not sure what to do
Do you have “shipping profile, Returns profile, and Payment profile” set? This error is shown if ALL 3 are not set. I don’t offer returns on international and have no problems
hiya! yep all 3 are set… Are you in the UK at all?
all the best
No, USA. Have you Refreshed your token? Clicked the “Update Profiles” from the dropdown?
Yep & yep… so confused…
Your selected return profile probably uses out-dated settings.
• Create a new return profile on the eBay website
• In GarageSale select “Update profiles” from the return profile menu.
• Select the newly created return profile.
More about profiles:
https://manual.iwascoding.com/gs8/en/Miscellaneous-eBays_Business_Policies.html
Hiya! yes i acutally ended all my listings. ready to restock… so i sorted my policies out… so all brand new…
Done update profiles…
All the best
There is always the Microsoft solution from my short-lived experience on the"dark side". Shut down and restart the computer. Worth a try
hahaha. i had the same thought 30 mins ago… no luck
