GS 7.0.14b5
Is Reveal Original supposed to work in Orders? It doesn’t matter which Smart Group or order I select, I always get this same dialog:
I click Fix and have waited a long time but nothing changes.
I backed up my db and even tried the debug start options -
First tried Rebuild Index -
restarted and tried auto repair corrupt database.
Still get the above dialog when selecting any order then Reveal Original.
Reveal Original works fine in Listings.
any ideas? Its not a huge deal right now because I don’t have that many orders
but one can dream
ilja
#2
Sorry, I couldn’t reproduce this at my place.
If you are willing to send my your current library via DropBox, we can look into this issue. Here is what you’d need to do:
- In GarageSale, choose “Help” menu > “Open Library folder”
- Zip up the directory GarageSale.leveldb
- Send me the resulting zip file via this DropBox upload form:
https://www.dropbox.com/request/oCg4ndGE2E5PefLWkIpb
Yes, I have the same problem.
Reveal Original on any Order gives this same error dialog.
And Reveal Original DOES work for Listings.
ilja
#5
I tried to replicate the problem with the libraries from @schwane and @Neal, but couldn’t find a single order that produced the error.
Does the error go away if you restart GarageSale?
Yep. Still happens after relaunch. Happens on Any order in Any Smart Group.
I have 19000 orders…
I also just got a crash clicking on an order in a smart group. crashLog below.
Order Smart Group Click Crash.txt.zip (24.5 KB)
ilja
#7
Yes! that fixed it for me, thank you!
system
Closed
#10
