GS 7.0.16 (841) bug
I listed an item with the wrong weight.
I adjusted the weight in the Shipping Options section under Package. ( I use business policies if that matters). Changed nothing else.
Then Revised the listing with “Revise Selected Properties Only” and selected “Shipping Options”
Then Revise Listing.
Says Revising
Progress bar finished, but when I checked the item, it hadn’t been revised. There is no update in the section with listing revisions.
If I use “Revise Entire Listing” - it works fine, the listing gets updated with the correct weight and shows the listing as been revised.
