I used to get a lot of listings when I used the search field in the upper right. Now, I only get a few or none. This started about 1 month ago. Thank you.
Hi CAL,
can you please click on that little magnifying glass in the search field and check if you have “All fields” selected there?
Thank you for your quick reply Kristian. I checked and it does have All Fields selected. However, it also had Show exact matches only selected as well. Unchecking it appears to have resolved my problem. Thank you, CAL
