Running: macOS Sierra 10.12.3
GarageSale 7.0.7 (795)
When I perform a search for an item, I highlight the item which I want then close the search window. The item highlighted is now no longer visible in the left hand pane
That’s certainly not the intended behavior. I just tried to reproduce it, but the selected listing remained selected after I left the search mode.
Do you see anything logged to the console utility (under /Applications/Utilities) from GarageSale when you selected the listing from the search results or leave the search mode
I’ve found that double-clicking on it helps. It ensures that it is selected and not just highlighted.
This the log produced with the FILTER GARAGESALE ON
The actual log is too large to send in this message, so I have included the part only from when the process is “idle”. I have kept the remainder of the log from startup if you want it as well.
Times in seconds are approximate.
15:36 Started GarageSale
15:38:19 GarageSale running but idle
15:42 Performed search
15:43 Selected the item I wanted from the search results
15:43:40 Closed the search results window to return to the main GS window.
Note. 1. When the search box is closed, the process is returned ALWAYS to the top of the file tree window, not to the point in the tree where I commenced the search.
I have some attachments of GS Windows through the process. I have forgotten how to add them to this message.
CONSOLE LOG:
default 15:38:13.218691 +0800 GarageSale 0x608001461280 opened /Users/davide/Library/Keychains/login.keychain-db: 926968 bytes
default 15:38:13.219120 +0800 GarageSale 0x608001461280 closed /Users/davide/Library/Keychains/login.keychain-db
default 15:38:13.219302 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:38:13.219883 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:38:13.220442 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:38:19.874072 +0800 GarageSale TIC TCP Conn Cancel [1:0x618000197aa0]
default 15:38:19.874163 +0800 GarageSale TIC TCP Conn Destroyed [1:0x618000197aa0]
default 15:38:19.874354 +0800 GarageSale __nw_socket_service_writes_block_invoke sendmsg(fd 26, 85 bytes): socket has been closed
default 15:42:47.770582 +0800 GarageSale [0x7f8362a0dc00] Releasing session
default 15:43:16.221195 +0800 GarageSale 0x600000870a80 opened /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db: 4636 bytes
default 15:43:16.221248 +0800 GarageSale 0x600000870a80 closed /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db
default 15:43:16.221621 +0800 GarageSale 0x600001463240 opened /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db: 50744 bytes
default 15:43:16.221678 +0800 GarageSale 0x600001463240 closed /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db
default 15:43:16.221869 +0800 GarageSale 0x6000018748c0 opened /Users/davide/Library/Keychains/login.keychain-db: 926968 bytes
default 15:43:16.222214 +0800 GarageSale 0x6000018748c0 closed /Users/davide/Library/Keychains/login.keychain-db
default 15:43:16.223402 +0800 GarageSale loading /Users/davide/Library/Keychains/login.keychain-db
default 15:43:16.225571 +0800 GarageSale getting current attributes…
default 15:43:16.225608 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:16.226235 +0800 GarageSale looking at 16 attributes
default 15:43:16.226299 +0800 GarageSale finished: 76bb4ce9f13fcc39e7dc1e3aa8a127c3289c6cbf6b380589fae5dc6b05ae3cb1
default 15:43:16.228999 +0800 GarageSale getting current attributes…
default 15:43:16.229035 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:16.229425 +0800 GarageSale looking at 16 attributes
default 15:43:16.229482 +0800 GarageSale finished: 1e3ad4d76afe857c1be56a9e120f159748ce589f60413ecc308f9a4d4fa402ca
default 15:43:16.258373 +0800 GarageSale getting current attributes…
default 15:43:16.258412 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:16.258884 +0800 GarageSale looking at 16 attributes
default 15:43:16.258948 +0800 GarageSale finished: 0e0a05c1a69d17c62e4946c6f93d7af5ba41640c9754ca0a567e5be4d8e46f93
default 15:43:16.560861 +0800 GarageSale [0x7f836329fe00] Created session
default 15:43:16.621844 +0800 GarageSale [0x7f8363b3d000] Created session
default 15:43:16.681202 +0800 GarageSale #WK: Starting frame load, frame = 0x1205c6000, main = 1
default 15:43:16.682052 +0800 GarageSale #WK: Starting frame load, frame = 0x1205c6000, main = 1
default 15:43:16.909680 +0800 GarageSale #WK: Starting frame load, frame = 0x1205c6000, main = 1
default 15:43:17.132065 +0800 GarageSale [0x7f8362573400] Releasing session
default 15:43:17.132132 +0800 GarageSale [0x7f83639b7200] Created session
default 15:43:17.132462 +0800 GarageSale [0x7f83639b7200] Decoding: C0 0x017701E5 0x0018304A 0x22111100 0x00000000 56295
default 15:43:17.132489 +0800 GarageSale [0x7f83639b7200] Options: 375x485 [FFFFFFFF,FFFFFFFF] 0001D060
default 15:43:17.134152 +0800 GarageSale [0x7f83639b7200] Decoding completed without errors
default 15:43:17.183864 +0800 GarageSale getting current attributes…
default 15:43:17.183904 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:17.184408 +0800 GarageSale looking at 16 attributes
default 15:43:17.184473 +0800 GarageSale finished: 76bb4ce9f13fcc39e7dc1e3aa8a127c3289c6cbf6b380589fae5dc6b05ae3cb1
default 15:43:17.186815 +0800 GarageSale getting current attributes…
default 15:43:17.186851 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:17.187255 +0800 GarageSale looking at 16 attributes
default 15:43:17.187318 +0800 GarageSale finished: 1e3ad4d76afe857c1be56a9e120f159748ce589f60413ecc308f9a4d4fa402ca
default 15:43:17.219217 +0800 GarageSale getting current attributes…
default 15:43:17.219255 +0800 GarageSale filling 16 attributes for type 2147483648
default 15:43:17.219711 +0800 GarageSale looking at 16 attributes
default 15:43:17.219771 +0800 GarageSale finished: 0e0a05c1a69d17c62e4946c6f93d7af5ba41640c9754ca0a567e5be4d8e46f93
default 15:43:17.247974 +0800 GarageSale 0x61800067fec0 opened /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates: 20460 bytes
default 15:43:17.248037 +0800 GarageSale 0x61800067fec0 closed /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.248970 +0800 GarageSale loading /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.250866 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.251026 +0800 GarageSale 0x6180006765c0 opened /Library/Keychains/System.keychain: 119200 bytes
default 15:43:17.251126 +0800 GarageSale 0x6180006765c0 closed /Library/Keychains/System.keychain
default 15:43:17.252088 +0800 GarageSale loading /Library/Keychains/System.keychain
default 15:43:17.254275 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.254608 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.254897 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.255157 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:17.255350 +0800 GarageSale TIC TCP Conn Start [44:0x61800019e850]
default 15:43:17.310728 +0800 GarageSale [0x7f8362a90000] Created session
default 15:43:17.318433 +0800 GarageSale [0x7f8362c1a400] Created session
default 15:43:17.321443 +0800 GarageSale #WK: Finished frame load without error, frame = 0x1205c6000, main = 1
default 15:43:17.325722 +0800 GarageSale [0x7f8362c1a400] Releasing session
default 15:43:17.325781 +0800 GarageSale [0x7f8362c1a400] Created session
default 15:43:17.326079 +0800 GarageSale [0x7f8362c1a400] Decoding: C0 0x01CC0177 0x001D304A 0x22111100 0x00000000 41914
default 15:43:17.326103 +0800 GarageSale [0x7f8362c1a400] Options: 460x375 [FFFFFFFF,FFFFFFFF] 0001D060
default 15:43:17.327505 +0800 GarageSale [0x7f8362c1a400] Decoding completed without errors
default 15:43:17.331640 +0800 GarageSale [0x7f8362a90000] Releasing session
default 15:43:17.331687 +0800 GarageSale [0x7f8362a90000] Created session
default 15:43:17.331885 +0800 GarageSale [0x7f8362a90000] Decoding: C0 0x017701E1 0x0018304A 0x22111100 0x00000000 55965
default 15:43:17.331910 +0800 GarageSale [0x7f8362a90000] Options: 8x-1 [00000000,017001E0] 0001D060
default 15:43:17.332593 +0800 GarageSale [0x7f8362a90000] Decoding completed without errors
default 15:43:17.332859 +0800 GarageSale [0x7f8362c1a400] Decoding: C0 0x01CC0177 0x001D304A 0x22111100 0x30060001 41914
default 15:43:17.332883 +0800 GarageSale [0x7f8362c1a400] Options: 8x-1 [00000000,01C80170] 0001C060
default 15:43:17.333434 +0800 GarageSale [0x7f8362c1a400] Decoding completed without errors
default 15:43:17.551065 +0800 GarageSale TIC TCP Conn Event [44:0x61800019e850]: 1 Err(0)
default 15:43:17.551091 +0800 GarageSale TIC TCP Conn Connected [44:0x61800019e850]: Err(0)
default 15:43:17.551185 +0800 GarageSale TIC Enabling TLS [44:0x61800019e850]
default 15:43:17.822219 +0800 GarageSale TIC TLS Event [44:0x61800019e850]: 2, Pending(0)
default 15:43:17.822315 +0800 GarageSale TIC TLS Event [44:0x61800019e850]: 11, Pending(0)
default 15:43:17.822702 +0800 GarageSale TIC TLS Event [44:0x61800019e850]: 14, Pending(0)
default 15:43:17.829996 +0800 GarageSale TIC TLS Trust Result [44:0x61800019e850]: 0
default 15:43:18.097874 +0800 GarageSale TIC TLS Event [44:0x61800019e850]: 20, Pending(0)
default 15:43:18.098205 +0800 GarageSale TIC TCP Conn Event [44:0x61800019e850]: 8 Err(0)
default 15:43:18.098231 +0800 GarageSale TIC TLS Handshake Complete [44:0x61800019e850]
default 15:43:18.098761 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:18.099042 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:18.099346 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:18.099639 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:18.099913 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:20.965681 +0800 GarageSale TIC TCP Conn Cancel [44:0x61800019e850]
default 15:43:20.965740 +0800 GarageSale TIC TCP Conn Destroyed [44:0x61800019e850]
default 15:43:20.965916 +0800 GarageSale __nw_socket_service_writes_block_invoke sendmsg(fd 53, 31 bytes): socket has been closed
default 15:43:32.325532 +0800 GarageSale 0x618000460d00 opened /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db: 4636 bytes
default 15:43:32.325594 +0800 GarageSale 0x618000460d00 closed /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db
default 15:43:32.325943 +0800 GarageSale 0x618000878180 opened /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db: 50744 bytes
default 15:43:32.326006 +0800 GarageSale 0x618000878180 closed /var/folders/25/0fgr50y10zg7w0rzcrv172dw0000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db
default 15:43:32.326233 +0800 GarageSale 0x618000878280 opened /Users/davide/Library/Keychains/login.keychain-db: 926968 bytes
default 15:43:32.326591 +0800 GarageSale 0x618000878280 closed /Users/davide/Library/Keychains/login.keychain-db
default 15:43:32.327553 +0800 GarageSale loading /Users/davide/Library/Keychains/login.keychain-db
default 15:43:32.329755 +0800 GarageSale 0x610000a75680 opened /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates: 20460 bytes
default 15:43:32.329811 +0800 GarageSale 0x610000a75680 closed /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.331352 +0800 GarageSale loading /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.333458 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.333601 +0800 GarageSale 0x60000186a040 opened /Library/Keychains/System.keychain: 119200 bytes
default 15:43:32.333684 +0800 GarageSale 0x60000186a040 closed /Library/Keychains/System.keychain
default 15:43:32.334869 +0800 GarageSale loading /Library/Keychains/System.keychain
default 15:43:32.337086 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.337339 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.337637 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.337875 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.338043 +0800 GarageSale TIC TCP Conn Start [45:0x60800019b380]
default 15:43:32.502338 +0800 GarageSale TIC TCP Conn Event [45:0x60800019b380]: 1 Err(0)
default 15:43:32.502369 +0800 GarageSale TIC TCP Conn Connected [45:0x60800019b380]: Err(0)
default 15:43:32.502465 +0800 GarageSale TIC Enabling TLS [45:0x60800019b380]
default 15:43:32.654748 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 2, Pending(0)
default 15:43:32.654857 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 11, Pending(0)
default 15:43:32.655264 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 22, Pending(0)
default 15:43:32.655460 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 12, Pending(0)
default 15:43:32.655496 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 14, Pending(0)
default 15:43:32.663965 +0800 GarageSale TIC TLS Trust Result [45:0x60800019b380]: 0
default 15:43:32.803300 +0800 GarageSale TIC TLS Event [45:0x60800019b380]: 20, Pending(0)
default 15:43:32.803657 +0800 GarageSale TIC TCP Conn Event [45:0x60800019b380]: 8 Err(0)
default 15:43:32.803685 +0800 GarageSale TIC TLS Handshake Complete [45:0x60800019b380]
default 15:43:32.804138 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.804416 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.804662 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.804919 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:32.805166 +0800 GarageSale skipping upgrade for locked keychain /Users/davide/Library/Keychains/Microsoft_Intermediate_Certificates
default 15:43:36.347139 +0800 GarageSale subsystem: com.apple.AppKit, category: Layout, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 1, privacy_setting: 0, enable_private_data: 0
error 15:43:36.347245 +0800 GarageSale Detected missing constraints for . It cannot be placed because there are not enough constraints to fully define the size and origin. Add the missing constraints, or set translatesAutoresizingMaskIntoConstraints=YES and constraints will be generated for you. If this view is laid out manually on macOS 10.12 and later, you may choose to not call [super layout] from your override. Set a breakpoint on DETECTED_MISSING_CONSTRAINTS to debug. This error will only be logged once.
default 15:43:40.505385 +0800 GarageSale [0x7f8363b3d000] Releasing session
default 15:43:40.505490 +0800 GarageSale [0x7f836329fe00] Releasing session
Thanks Brian. Tried that but it still crashes.
Also tried in Safe Mode and with all other apps closed but no difference.
