Hi
When I perform a search with ‘Search this group only’ selected. I get the spinning ball which then hangs the application.
Is anyone else getting a similar behaviour?
Hi
For me it works perfectly fine.
Can you please also follow these instructions to gather more diagnostic data?:
Launch GarageSale if you don’t have it already running
Open the “Activity Monitor” application (under /Application/Utilities)
Select GarageSale from the list of running applications in Activity Monitor
Now try to reproduce the beachball/hang to come up for several seconds.
Chose “View” menu > “Sample Process” (Activity Monitor will probably ask you for an admin password at this point)
Wait while the sample is taken
Save the sample output into a file and send it to us (or post it here as a zip file).
Looks like it is just my database again. I have a lot of auto-listing occurring at the moment so it will be a couple of days before i can force freeze GS. I will then send you the report as requested.
Hasn’t happened again, Kristian. It may have had something to do with the queueing problems I am having. I will get back to you if I can capture it again.
