Hi - using 7.0.13. Got a message from Ebay today about some text I had in an info box in the sidebar of a pro template. Any way to search for that text? Thanks
If the problem is the text, look in the right hand column, tab “properties” and scroll down until you find the info boxes texts, if that’s the issue…
I know where the text is, just if it is searchable as I have a lot of listings to change…
Mmh as far as I know, it is not possible to search in GS 7. Does you listings use different texts? Do you want to use the same text for all listings? In this last case, you might consider to do a bulk edit of that info boxes texts using the only one which does not give you any troubles over ebay.
