I have a smart group to show me multi-item running auctions. I use Quantity Greater Than 1 and Status is running. I had an auction with 7 items, and it appeared in the group just fine. I sold 4 of the 7, and the listing disappeared from the group. Quantity is still 3, so I would think it should still appear in the group. I re-defined the group, but no change.
Seles the auction and choose “File” menu > “Export Listing”. You can send the file directly in your reply box, or use the private message function to send it to me. Please compress as .zip before sending.
