I cannot access the example inventory CSV file from GarageSale 7 manual.
In “Inventory Section > Creating New Inventory Items”, I clicked the “here” link at the bottom of the page and nothing happened.
I then tried right-clicking the link, selected “Copy link”, pressed Cmd+Shift+G, copied the link: “file:///Applications/GarageSale.app/Contents/Ressources/GarageSaleManual.help/Content/Ressources/English.lproj/Inventory.csv.zip”.
There is an “unknown folder” error.
I also tried accessing folders that are upper in the path. Without success.
N.B. I’m using GarageSale in French language.
Can the problem come from user permissions?
Thanks
