For the subscription model on GS8
I have 9600 items currently on ebay. Which re-list every 30 days. Will those count as GS listings?
I just use GS to list new items, that is all.
I don’t need the syncing feature.
In fact I don’t use most GS features, I do everything in my MySQL / Filemaker database
then export the XML and import into GS just to list.
So as long as I stay under the 50 items limit of new listings per month, I can use the Non-pro version?
I list about 50 new items per month, the rest are are re-listings from sold items, so I can use the ebay re-list feature there.
To confirm the new version has the features I needed and I think I asked about a few times in the past.
Ability to use more than 1 picture with the XML import feature. (from your new features list looks that that is possible now)
Allow “Allow buyers to remain anonymous to other eBay users” feature. I know you said ebay told you not to use it, but it is still there on ebay and seems to be not going away. At least let us use it until it goes away. Many sellers copy the items I sell and it is a good way to deter them. They even copy my photos and descriptions…
Allow Set Rate in GS for Promoted listings. (Is that already in GS7? I never asked about it before)
If I have eBay store, then GS should only show cost of listing item if I go over my free listing Store limit.
If I go for Pro subscription version.
The help and support is upgraded?
eg. I will get help with making separate versions of my xml / html for the web and mobile versions of ebay listings?
ie you don’t make separate charge for that sort of help.
thank you ~
ps, your forum software is really good!
