I believe this is my final problem in updating to GS 7. I imported approximately 50 live listings from eBay in order to fix the “see full item description” button at the bottom of a truncated ad. I was able to successfully revise half of the listings and upload the changes to eBay via GS 7. However, although I could revise the other half of the imported listings, GS 7 does not let me upload the changes to eBay because GS 7 does not recognize these as live listings. Therefore, I cannot finish the process. Do you have suggestions regarding this problem?
Background: my thought is that some of the listings were re-listed using the eBay re-listing tool, some of them may have been re-listed several times in fact. Could this be causing the problem, although some of the items listed through eBay’s re-listing tool were able to be revised using GS 7 and they display perfectly on eBay.
Please note: I could not do ‘Repair Image Links’ in bulk, it would only let me do it one at time.
Thank you for the support.
