Updating/Synchronizing Listings Not working
Hi, i’ve finally bought Garagesales because it’s very useful: much better than TL.
Actully, if i try to “update all the listings” it doesn’t work. Listings remains as if never touched.
I mean: i’ve edited all the ebay selling rules (payment, shipping, refund) directly via web on ebay website, and on ebay panel is everything ok. When i try to open the same listings on GS, it says that all the rules are not known and that i need to add selling rules to avoid mistakes on the list (something like that).
Is there a way to “synchronize” the listings as i used to do on TL?
Thank you for your help :slight_smile:
Sorry, that feature is still missing from GarageSale. Your only option would be to delete the listing and using the “Import from My eBay” command to import it again. But that has other, most likely, unwanted side-effects, like mangled description and design HTML.
Sorry for not being able to give you a better answer at the moment.
I did what you suggested (deleted and reimported). Not so bad :slight_smile:
Thank you
