“internal error to the application” means eBay is having problems at the moment. I guess somebody was brave enough to reboot their server on Monday morning.
I tried again now and it only shows listing fees (not even all of them) but I’m not able to upload anything. I don’t think this is a problem with ebay.
Did you try with only 1? I have another idea: press alt-comand-zero and send a screen of the activity panel. This is usually due to other working process like auto-relistings.
I just tried 16 and it doesnt work. Calculates listing fees and is incomplete. I can’t list them.
I guess u wanted me to send a shot of the activitiy viewer? it just verifys the listing and then goes blank.
If 1 works, it means that it just requires much time if you start together much listings. When the activity viewer goes blank, does anything change in the launch panel?
Did you try to refresh your ebay token in preferences? It might help.
the only thing i see in the activity viewer is verifying listings, then nothing (as pictured above). tried refreshing token and didn’t make a difference.
