Thanks Kristian for the help. I will try that. Currently it’s unchecked so I will check it and see.
I do like the warnings that it gives me as that is how I find some errors but yea its strange how it seems to verify the batch and just gray out the submit as if there is something pending to fix but it works on the 2nd attempt, almost every time.
