Why does the remove click box and add text box move to opposite corners of the pictures between listings? It also changes colors and on some listings it is on the top right and others the top left.
The button style has been updated in GarageSale 8 listing designs.
The first screenshots shows the button style used in the new GarageSale 8, the other screenshots shows the button style used in older listing design versions.
If you use no listing design in GarageSale 8.0, the old button style is shown. In the upcoming GarageSale 8.1 this has been updated, the new button style will then be shown as well.
Also, due to the major changes of the listing designs in GarageSale 8, the position of the button has been changed in some layout options.
Hope this helps,
Kristian
