I just managed to get hold of a iPad mini 6, and was wondering if it would run on it, as well as my iMac?
I did a search of the forum but I found nothing…doesn’t sound promising so far, any of your helpful tips appreciated, thanks
EDIT…think I found Garagesale Touch! let me see if I can find it in the App Store, but the big question is, can I transfer all my listings from iMac onto iPad? hmmm, like import them…I have read a bit and it says I can share on Garagesale 6, but I have 7.0.20 856. On deeper delve it says that Touch is no longer available, is there a workaround if I already have a mac version?
I believe I remember seeing this question asked and the answer is no iPad possibilities. Also GS7 will likely be broken by ebay in early January so you will need to update to GS8
Do you know what they mean by a limit of 50 uploads for the standard version of GS8? Does that include your automatically relisted and unsold items, or is it just for new listings?
Any listing that GS lists or relists. If you let the unsold continue without GS doing anything to it, it doesn’t count. Ebay charging the next 30 days doesn’t count.
